Micro Holes
支持for UP300. To report a bug, post with a title [BUG REPORT]. To request a feature, post with a title [FEATURE REQUEST]
Post Reply
allineatorisorridi
加入:Thu Mar 14, 2019 1:40 pm
Micro Holes
Postbyallineatorisorridi»Tue Apr 09, 2019 9:36 am
Hi everyone, i've a problem with my up300!
The printer makes micro holes in the printed surface, i've changed the layer thickness, the extruder ratio and other parameters but without any luck.
Thanks in advance!
WhatsApp Image 2019-04-09 at 11.22.14.jpeg (67.03KiB)Viewed 3986 times
WhatsApp Image 2019-04-09 at 11.22.14(1).jpeg (60.4KiB)Viewed 3986 times
WhatsApp Image 2019-04-09 at 11.22.14(2).jpeg (79.01KiB)Viewed 3986 times
Top
bjorn
加入:Fri Aug 10, 2018 6:00 pm
Re: Micro Holes
Postbybjorn»Wed Apr 10, 2019 6:00 am
what type of filament, and how is the relative humidity where you are?
Top
allineatorisorridi
Re: Micro Holes
Postbyallineatorisorridi»Wed Apr 10, 2019 9:03 am
Solved!!! The problem is a bug in the new release that create some "pause layers" (marks in red). Downgrade to the previuos version (2.5.x) solve this problem and also the wall not attached to the central infill is solved!:D
Top
bjorn
Re: Micro Holes
Postbybjorn»Wed Apr 10, 2019 1:16 pm
Are these the beta versions they release, or proper releases?
Unless a beta version (or even a proper release for that matter) addressees a specific issue you have I would simply skip over those, from reading this forum they cause more issues than they fix,
Top
allineatorisorridi
Re: Micro Holes
Postbyallineatorisorridi»Wed Apr 10, 2019 1:23 pm
Was not a beta, was the stable 2.6... I assume the the 2.5 is more stablish!:roll:
Top
Post Reply
