Just tried the default 100% Fill on a model with default settings, 0.1mm layers.
The outer will is still not attached to the infill, with the worst affect being on the right rear side ( that is, the right side, or rear side, will show the worst separation between the wall and the fill, or in a circle, the right, rear side of the print. )
Is anyone from Tiertime able to confirm that you're aware of the problem? It seems to be affecting 100% of your users presently.
Thanks
David.
[Bug Report] Wall still not attached to infill 19th March 2019 firmware.
Re: [Bug Report] Wall still not attached to infill 19th March 2019 firmware.
File that generates the test shape;
- Attachments
- 3mm square box test for walls.zip
- (425Bytes)Downloaded 168 times
- allineatorisorridi
- 加入:Thu Mar 14, 2019 1:40 pm
Downgrade to software 2.5.x solve the problem!
What is the board firmware to support this? Now I've upgraded it, it just errors out when I try to run 2.5.x -
我不是在e it's safe to downgrade after the recent string of firmware failure updates, especially as I'm on the latest.
