Hi Everyone and thanks in advance.
I have a problem with my new UP300! I've done both auto and manual calibration but from the front of the plate to the back these is more than 2mm of difference, and is the maximum amount that the software let me set. So if machine print on the back correctly it can't print on the front because is too high, and if i calibrate it so the front can print in the rear is too low and scratch the plate, even if I set 0mm on the back points and +2mm on the front ones.
Any help?
